WB Greenstar 25i erp Relocation
Discussion in 'Plumbers' Talk' started by Matt_Smith85, Jul 13, 2018.
  1. Matt_Smith85
    Matt_Smith85 New Member
    Boiler is WB Greenstar 25i combi and is currently in a cupboard in the bathroom. We are knocking through so it needs to be relocated. Only viable options are to the loft space (not ideal) or the garage (more work/cost but preferable).
    Does anyone know if my WB combi would have issues moving it to the ground floor? I've, does it need gravity assistance? This will more likely make my decision for me.
    Thanks
  2. Bob Rathbone
    Fit the combi in the garage, it will be just fine.
  3. Matt_Smith85
    That's the answer I was looking for. It's bad enough being in the loft myself, servicing a boiler.....no ta!!
  4. Matt_Smith85
    Thanks Bob ;)
  5. The Teach
    The Teach Well-Known Member
    should not be a problem moving the boiler,only gravity aspect would be the condense pipework again that will not be a problem for a registered installer.
    Budget for a new flue pipe and any flue turret gaskets that may be required,again your installer will be in the know ;).
    If your boiler has a wb warranty you will have to inform them prior to moving the machine o_O
