Hi guys I’m looking for a bit of advice, I’m after building a single block shed out my back garden, and the walls feel wet all the time when it rains and there is water seeping in through them and leaving a puddle on the concrete slab from it running down the walls. I have put a sealer on the outside of the walls and inside walls and I have added a slurry tanking now also and still no luck. I don’t have the shed insulated or anything yet because I want to get this sorted first, the roof also has condensation droplets on it also. There is no leaks or anything from the roof I have checked it on a number of occasions. Any help would be great because I’m not sure on how to sort this out? Would it be an easy thing to fix? Is it just condensation causing the water on the ground from the walls? thanks In advance
