wet underfloor heating
Discussion in 'Plumbers' Talk' started by tiredman, May 2, 2010.
  1. tiredman
    tiredman New Member
    i am doing a new bathroom and customer wants wet ufh in this room. the room is 4.5x2.1m anybody know of a simple to lay 1 room system that would be suitable?
  2. Dreadnaught Heating
    Dreadnaught Heating New Member
    While Underfloor Heating is 'straight-forward' to comprehend, design & install, 'Simple' it is not......
    May I suggest that you engage yourself on a Training Course that most of the big players lay on on a regular basis,
    the Uponor one is very good, based in Lutterworth, Leics.
    DH
  3. hibeealex
    hibeealex Member
    There's lots of different manufacturers around and as DH says it pretty straight forward, go for something like polyplumb, no fancy tools needed,and simple enough to install, if you ask them they will also send you a video of the different laying methods, depending on floor base, if you get stuck just ask on here again, its really not rocket sceince either
  4. Tony Soprano
    Tony Soprano New Member
    People such as john guest,hepworth and poluplumb make single zone underfloor kit,this comes with all relevant parts and is very simple to install
    speak to your local merchants and they can put you in touch with the particuliar local rep .
  5. Captain Leaky
    Captain Leaky New Member
    I use Uponor or John Guest. As advised, go on a mfr course.
  6. Dick Puller
    Dick Puller New Member
    What is the floor construction & finish? If you don't do much UFH, it may not be worth your while going on a 'manufacturers' course.
  7. ww gas ltd
    ww gas ltd New Member
    Hello
    A good system is nu-heat. You can have it as big as u like or as little. very good company
