What adhesive for glass/mirror tiles
Discussion in 'Tilers' Talk' started by drive, May 21, 2020.
  1. drive
    drive New Member
    Can someone recommend an adhesive for glass/mirror tiles. Tiles has kind of protection paint at the back side. It's not a massive job (60x120cm) but I don't want to use one of those "tube" silicone based adhesive. Any recommendations? Thanks
  2. Wayners
    Wayners Screwfix Select
    Mirror adhesive. Comes in mastic tube..
    Or sticky pads
    Or white star tile adhesive. Maybe
    Not sure what you want to do. Are these in a wet shower or on bedroom walls
  3. Mike58
    Mike58 Screwfix Select
  4. drive
    drive New Member
    It's gonna by in our hallway.
  5. Wayners
    Mirror sticky pads then. Or you can use mirror mastic. It's a polymer not silicone. Hold in place with frog yellow to stop the slide. Only trouble with pads is it's instant grab. Hard to get in correct position
  6. Mike58
    As linked above - right material for the job.
  7. Wayners
    Ah. I flick through posts a bit quick and answer. Sometimes missing the fact question had already been answered. I also try link to forum sponsors vs others just to play fair. I've bought both mirror mastic and pads from Screwfix.
  8. Mike58
    Looks as though they now stock one: https://www.screwfix.com/p/geocel-trade-mate-mirror-fix-white-310ml/95057
    The OP needs to remember - prepare the surface and use it in accordance with instructions. Then WAIT. Also, if you do not mind having two holes to repair, screw batten to the wall below which will stop vertical slide and use tap to position left to right and ensure it is properly aligned
    WillyEckerslike and Wayners like this.
  9. drive
    drive New Member
  10. Mike58
    What is te point?
    You come here asking for advice, you get good advice from Wayners and myself and then ignore it with a suggestion to use a totally inappropriate adhesive that even the instruction say should not be used.
    WillyEckerslike likes this.
  11. drive
    drive New Member
    Where exactly the instruction say that?
    Adesilex P10 is designed for glass tile, glass mosaic and marble mosaic, and is ideal for light translucent natural stone. Mix with MAPEI's KeraplyTM for increased performance and submerged installations.
  12. Mike58
    Read the data sheet:
    Do not use Adesilex P10 in the following cases:• on wood or wooden conglomerates;• on metal, rubber, PVC or linoleum surfaces
    At what are mirrors backed with? Metal.
  13. drive
    drive New Member
    Read my first question:
    These are proper tiles, not just a mirror with foil.
