What are these grooves for in a surface pattress box
Discussion in 'Electricians' Talk' started by mfizz, Jul 24, 2021.
Tags:
  1. mfizz
    mfizz New Member
    Hi All,
    Just wondering what the purpose of these grooves are in a pattress box?
    Can these be broken off to allow wires to feed through?
  2. Ind spark
    Ind spark Active Member
    You break them out to bring canles in.
  3. I-Man
    I-Man Screwfix Select
    *cables
  4. Ind spark
    Yeah that's it :)
  5. Bazza
    Bazza Screwfix Select
    You’ll only break them off once, only to find you’ve wrecked the box.
    The way to avoid damage is to cut down the side with a junior hacksaw, and then remove the unwanted bit with a pair of long nosed pliers.
  6. Sparkielev
    Sparkielev Screwfix Select
    Better to use soft boxes those bakerlite plastic boxes are carp
  7. Ind spark
    Especially if you screw them to a wall with an impact driver, you end up with 5 pieces.
    Unless that's just me.:)
    Sparkielev likes this.
  8. Tony Goddard
    Tony Goddard Screwfix Select
    I always hate that noise you get when you ever so carefully tighten up a socket plate and the box makes a cracking noise - the PVC ones used with mini trunking Sparkielev mentions are far better!
  9. Bob Rathbone
    Bob Rathbone Screwfix Select
    But some go yellow with time.
    Lectrician likes this.
