What does the diverter valve do?
Discussion in 'Plumbers' Talk' started by ivymic, Oct 8, 2009.
  1. ivymic
    ivymic New Member
    Buying a new boiler for a friend of mine to fit for me (don't worry he's a gas safe engineer!). I've looked at the worcester bosch greenstar 12i which looks to be pretty good for the money. Can you tell me what the optional diverter valve is/does? will I need it? there's no info on their site. I'm guessing it's instead of a motorised valve but wondered if someone with a bit of knowledge could confirm.
    Cheers
  2. Captain Leaky
    Captain Leaky New Member
    diverts water - it's optional 'cos it's unlikey you will ever need it!
  3. Supra
    Supra Member
    Why is it unlikely that he'll need it?
  4. mantor
    mantor New Member
    cos it's 'optional'.
  5. doing a bit
    doing a bit New Member
    if i remember correctly it is for the connection of a hot water cylinder, this is instead of a conventional y plan with separate 3 port and pump , does the boiler have a built in pump and exp vessel etc
  6. G Brown
    G Brown New Member
    Correct, unlikely to be needed unless you are running a combi with a cylinder.
  7. JGB Plumbing
    JGB Plumbing New Member
    I does exactly what has been said. It is a diverter valve for WBosch system boilers with a cylinder instead of the usual y or s plan valve set ups.
  8. ThreadJacker
    ThreadJacker Active Member
    Hi JGB Plumbing, it seems you registered 4 years ago and now you decide to make your first post, I love it.
  9. mantor
    mantor New Member
    I like a man who doesn't rush into things.
  10. musky1
    musky1 New Member
    Why did you marry that old tart of yours so quick then?,up the duff? :^O :^O
  11. ivymic
    ivymic New Member
    Yeah it's a system boiler, so pump exp. vessel all integral. I'm trying to reduce the amount of time the installation takes to get it done in a day (two blokes). I've got an old gravity system which I'm swapping over. Looks like this valve will be a good idea as far as saving time on labour goes.
    Cheers for replies.
