Another simple question I'm afraid. I've asked Screwfix support for help, but they have not responded. I am fitting 'Metro' tiles. These are 6mm tick and the edges taper to 4mm thick. I am looking for a suitable edging strip. The samallest I can locate is a 6 mm in white (https://www.screwfix.com/p/diall-6mm-round-pvc-tile-trim-white-2-5m/678gr). I do not know what the 6 mm refers to and whether this could be used. Help much appreciated, thanks. Steve
The 6mm refers to the thickness of the tile. Look up square edged tile trim, you’ll want a 6mm one, probably the best case scenario.
You need to look at Genesis https://www.genesis-gs.com/products/metal-tile-trim-1 Their Aluminium Straight Edge (ESA) comes in about 15 different sizes: https://www.genesis-gs.com/products...ght-edge-trim-2/esa-aluminium-straight-edge-1
