Hi All, I need to wall mount a Plasma TV on a bracket with 4 main fixing points (total weight about 35kg) onto a 4 inch thick block wall. What fixings would you recommend ? I was thinking of using some Fischer Nylon Plugs (Screwfix 20173-85) 10mm drill diameter with some chunky gauge 2.5/3" screws. Should I be using some sort of Anchor fixing instead, if so what would you recommend - Screwfix no. appreciated. Many Thanks.
http://www.screwfix.com/app/sfd/cat/pro.jsp;jsessionid=B45X5ZOV2GMU4CSTHZOCFFY?id=33836&ts=07389 Use these, nylon plugs will not hold. I have just fitted one and used EIGHT of the above to a red brick wall. You will need a few for a block wall.
Use 'Thunderbolts'. They screw straight into masonry without a plug. They are the business. You can buy 'em from decent builders merchants. This is a pic of them in the bottom right.
