What is it? What does it do? What is it for? How do you use it?
Discussion in 'Just Talk' started by MRY, May 16, 2022.
  1. MRY
    MRY Screwfix Select
    MAybe a thread for identifying tools or whatnot? I didn't put it in "tools" or wherever, in case there are non-tool things people want to find out about.Anyway.
    This looks like a thing for nibbling triangles out of something that has a straight edge. What is it? What is it for?
  2. MRY
    MRY Screwfix Select
    Here's another thing. Maybe some sort of protection when doing something? "Chainmail on a leather pad".
  3. Astramax
    Astramax Super Member
    Cornish Pasty crimper.
  4. Astramax
    This is used for metal burnishing or something to do with Blacksmithing like holding hot metal.
  5. Astramax
    London Victoria Gents Underground toilet emergency key for trap 3 fresh air vent opener .
  6. MRY
    MRY Screwfix Select
  7. stevie22
    stevie22 Screwfix Select
    The first object would be used for clipping an angle section to allow it bend.
    MRY likes this.
  8. FlyByNight
    FlyByNight Screwfix Select
    Or similarly. Take a piece of flat aluminium, turn a side up by say 25mm, then notch using the tool, then allowing the main sheet to bend .
    MRY likes this.
  9. koolpc
    koolpc Screwfix Select
    First object is used for castrating lizards
  10. MRY
    MRY Screwfix Select
    Interesting. Do you know what it's called? Used on quite thin section, I'd guess. TYVM.
  11. MRY
    MRY Screwfix Select
    Maybe "hand held notching tool". Anyway, great! Now I know what it's for.
