What size mitre saw?
Discussion in 'Carpenters' Talk' started by Martin.Stone, Sep 12, 2021.
  1. Martin.Stone
    Martin.Stone Member
    Hi
    I have some 100x100 posts to cut, I have an Evolution saw which I think has 210mm blade but it can’t go all the way through, so I cut then flipped and tried to cut again, not perfect! So was looking at a cheap secondhand one just for a cheap fix, I just don’t know what size I need to do 4x4 timber.
    Thanks
  2. ginger tuffs
    ginger tuffs Screwfix Select
    Set a stop up then then you get same size every time
  3. Martin.Stone
    Martin.Stone Member
    a stop?
  4. ginger tuffs
    Yes a stop set up desired length with length of 20 x 45 use a block clamp then you get correct size every time
  5. ginger tuffs
    So when turn wood around to get depth of cut it’s the same
  6. BillyBobToo
    BillyBobToo Active Member
  7. jimoz
    jimoz Screwfix Select
    12" for 4" cut.
    You get half the blade less the bore and a bit
    Might be some cheap old dewalt 305mm knocking around eBay?
