I'm just refitting my staircase/hallway out and ripped out all panelled doors, mounded skirting and architrave plus staircase spindles and coving etc. I just want clean lines. So I have to refit new skirting and architrave. I just want square, with no detail so I thought I might as well get some MDF cut into strips at B and Q either 12mm or 18mm what's a good size for architrave and skirting? I Was thinking 120mm skirting and 80mm architrave? It's easy out of 18mm MDF as my local B and Q stock 18mm not 12mm MDF sheets if 12mm would look better it's a 20 mile round trip. Thanks
Will look **** tbh. Better off sourcing some cheap mdf skirt with a tight pencil round. You won't have to buy whole sheet so probably less wasteage and better looking finish
But I don't want a pencil round? I don't want moulding and detail. I can get 14 X 2400mm lengths of 80mm from a sheet. I may put a small chamfer on the top edge but only a 5mm or so. Thanks
Height of skirting should be determined by ceiling height, no point having an 8" skirt when the ceilings 8', looks out of proportion. Check out Howdens joinery profiles, they do a square arrissed mdf design with a single groove running through, simple but not bad looking.
I have the burford traditional. The contemporary is what I meant by a tight pencil round. More of an arras as said above. I reckon it's about 4 quid a metre from memory but could be wildly wrong. You could even buy a 4" pencil round skirt and just fit it backwards with a slight arras either routered of block planed into it
Thanks, if I'm buying skirting and putting my own Arris on the edge would it not be cheaper to have a £20 sheet of MDF cut up into strips?
Cheaper for sure using an 8x4 board and ripping it down but then you’re gonna have loads of ‘fluffy’ edges to deal with when painting - loads of info on this site about painting MDF edges Yep, can be done using right materials and prep and a great finish achieved - just takes more time More money but can achieve same square edge finish with soft wood/pine Price up at a timber yard, usually cheaper than say BQ and longer lengths available so less joins on skirts Buy at finished size or buy bigger and rip down, may save some money Prime the lot with Zinnser BIN and that will also take care of the knots The choice is urs
Hi thanks, they will be just the 18mm top edge exposed, if I chamfer it, a little more. I have a spray set up in a dedicated workshop so will give it all a few coats of primer Then fit and some fine surface filler on the top edge and then caulk the skirting/wall joint Thanks
