Learning.DIY
New Member
I’ve removed the old caulking around some windows and in the top corners of one of them, the paintwork and plaster started crumbling off and now I have a large hole and some gaps. The other window is fine.
What is this usually caused by?
In those areas where there are deep large gaps in the corners, how should I deal with/ fill this?
For those areas where there is around a 2mm wide gap, it seems like the gap goes into the wall about 2cm - is it suitable to caulk straight away or should I fill it first (if so, what with)?
Advice appreciated.
Cheers!
Advice appreciated.
Cheers!
