Saddolin? Thanks for reply Tel. What kind of Sadolin would you suggest as I don't want it to look "painted" as it needs the "stained" look and I'm not familiar with Sadolin stuff.... the bloke in t'shop said Classic should do but on reading about it, it says to finish off with 2 coats Sadolin Extra. I've thought about doing it with a couple of coats of Dulux Woodsheen. I suppose i could use Ronseal 5 year outside, but I don't think that would be suitable for the inside. I've done the rest of the house with Ronseal 5 year Rosewood colour.
For the outside why not use the same Ronseal? Or I would use two coats of the Sadolin extra durable. Also for inside I would use exterior to handle the steam and water, if you dont want to change the colour you could try the clear coat http://www.sadolin.co.uk/homeowner/products/exterior/extradurableclearcoat/description Hope this is helpful
In the Sadolin blurb.. it reckons that to use the extra durable you should be using a base of Sadolin Classic and I don't want to be giving it 3 coats on a price as it's bigger than it looks in the pic. The Ronseal sounds good, I just don't want any moaning over the colour with it being over bare wood instead of over mahogany on the house. The Sadolin Clear sounds good inside, but I'm a bit worried about all the louvres' .... keeping each side clear of the other. I've another one to do in the area. I'm putting a gutter up to stop all the staining at the bottom. Decisions....decisions.
Guttercat, that building looks like a 'kit' rather than a bespoke item. So, I guess it'll have a manufacturer you could contact? I'd have thought that the assembly instructions would also have a 'maintenance' section. If no joy with either of above, then find a company who makes a very similar product and ask them
Eg: http://www.leisurebuildings.com/info/howto/maintain/ "Cuprinol 5-year Woodstain" Don't know about the inside, tho... Best to check a specific finish isn't recommended due to high humidity levels.
Too late my friends... the damage is done. (Estimate's in) Here's what I decided: 2 coats Ronseal 5 Year stain (water based) outside and 2 coats Wickes Satin Professional Microporous Woodstain 4 years,(solvent based) inside. Thanks Tel and devil's advocate. I just needed to talk it through. Sometimes I cant see the wood for the trees.
Yep - do and be damned don't and be damned, never easy is it! Your easy with me Tel IWS: I Was Searching for you
