HarryL1234
Screwfix Select
I bought a 1930s house which I'm modernising. The front wall of the master bedroom overhangs the downstairs bay window (see the pic supplied). I expected this wall to be of timber frame construction, but checking in the loft, the inner skin is made of concrete blocks, so it's at least a one block wall. Given the date of construction, would there be a steel beam or frame holding up the wall? If the wall isn't being held up by a steel beam, then is it being supported by a wooden beam? Would a wooden beam be used to support a concrete block wall?
