Hi. I'd like to avoid tiling the bathroom walls. Is there a way to protect the walls from the water without tiling?
Hi Fit shower boards, ! They also look good They’re 2.4 x 1.2 If you need to join them, you can get them with t & g edges Also corner and end trims regards Peter
Ha ha indeed ....., I did pre warn you though !! Loads of alternatives though, shower boards, as mentioned above. Most bathroom showrooms will have a display and samples you can look at and get an idea on price - depends if your fitting these yourself or getting someone in ? Also the link I posted to ‘Mermaid’ shows an array of alternative shower cladding systems that will be better priced than glass Do some research and compare prices, that’s a starting point
