Hi, Not sure which thread to put this in. I removed some of these which attached a telephone cable onto some skirting to paint the skirting. I would like to buy some new ones to put back into the skirting. Except I cannot find any of these small ones online. There are plenty of bigger ones for mesh fencing, etc.. Am I searching using the wrong term? The length is 10 mm and the width is around 6 mm . Anyone have any ideas where I can find them? Cheers.
Under the name Staples? Prefer these myself. https://www.screwfix.com/c/electrical-lighting/cable-clips/cat830572
Have you looked at these from our host? https://www.screwfix.com/p/tacwise-ct-45-cable-tacker-staples-galvanised-8-x-6-3mm-5000-pack/35078 Although I agree with @just pumps, I prefer the plastic ones.
Heres a trick a decorator taught me, clip cable with conventional plastic clips, run a bead of acrylic filler down each side and smooth in (but not where clips are, alow to dry, pull out clips, repeat where clips were, cable magically stays in place - very good for BT phone wiring.
