Which CCTV cameras - DIY project
Discussion in 'Electricians' Talk' started by baracus, Jun 11, 2019.
  1. baracus
    baracus Member
    Hello
    I want to install a HIKVison CCTV system myself, all the wiring is in place ie the builders ran wires to 5 outside points and the all run to a central location. Im happy that I need an NVR but not sure what I need to know to be able to decide which cameras I need.
    Im I right in assuming that this is perfectly within the reach of a DIY project.
  2. unphased
    unphased Screwfix Select
    Yes the latest CCTV kits are virtually plug and play. Even the NVRs are easy to use. Most popular seems to be the IP type which use Cat5 cable to connect up rather than the video and power leads.
  3. baracus
    baracus Member
    Thanks.
    Any suggestions for which kit to go for? More so which cameras?
  4. Peterdevon
    Peterdevon Active Member
    Budget?
  5. baracus
    baracus Member
    £60 - £80 per ?
  6. baracus
    baracus Member
    £60 - £80 per camera..
  7. peter palmer
    peter palmer Super Member
    Hiwatch/hilook from hikvision, cctvkits.co.uk
  8. Ronaldmc
    Ronaldmc New Member
    I just put in a Eyeride cam system with a POE recorder and 14 dome cameras. Brilliant quality images and easy install. Would totally recommend.
  9. Ronaldmc
    Ronaldmc New Member
    Now I bought 5 cameras and install them yet.
  10. peter palmer
    Must be desperate, if people aren't buying your crappy product in the US of A then I highly doubt they will bother to import it to the UK.
  11. Ronaldmc
    Ronaldmc New Member
    Why crappy? Can you explain?
  12. wartonwoodworks
    wartonwoodworks New Member
    Hello Baracus,
    Yes, I think you have made a good choice going for a Network Video Recorder (NVR) CCTV set-up. Basically, this is a digital setup, which uses Internet Portal (IP) to communicate between the NVR box, and the cameras. Because the system is directly linked to your router, it means you can view your cameras remotely, even via your mobile!
    Choosing a camera is difficult, because there are so many out there. I think you should buy the best resolution camera you can afford. The higher the resolution, the sharper and clearer the image.
    There are also other things you need to consider, such as the type of light detecting chip your camera uses. Here is a post on selecting home CCTV systems and cameras, you may find it useful.
    Any questions, then please let me know.
    Kind regards,
    Jon
