which MCB for Boiler ?
Discussion in 'Electricians' Talk' started by Pikerray, Jan 31, 2009.
  1. Pikerray
    Pikerray Member
    I have a 37Kw boiler to install, what size MCB will I need ?
    The run to CU is less than 1 metre on dedicated 6mm cable.
  2. Pikerray
    Pikerray Member
    I also have a heated Jacuzzi on a seperate dedicated circuit so what size MCB for this one ?
  3. CraigMcK
    CraigMcK Screwfix Select
    A big one!, 37kw is about 150Amps
  4. Pikerray
    Pikerray Member
    That cannot be right, the spec states an electrical power consumption of 175watts
  5. Clark Kent
    Clark Kent New Member
    Then you've quoted the GAS figure...
  6. syholl
    syholl New Member
    PMSL
    Haha, 150 amps...!!!
    If you are supplying the boiler with a dedicated radial. Then a 16 amp MCB on a 2.5mm T&E will be fine. Stick a 3 amp fuse in the fused connection unit and it will be OK...
  7. Clark Kent
    I've got in to the habit (when wring a new boiler circuit) of using 1 or 1.5mm T&E and a 6A MCB..
  8. Pikerray
    Pikerray Member
    What about the Jacuzzi circuit ?
    Also can I put the Smoke detector circuit on the same circuit as the burglar alarm ?
  9. Bandit12
    Bandit12 New Member
    Is that the size of round clip that fits it ??
    THINK YOU NEED A SPARKY
  10. Clark Kent
    Well what rating is the Jacuzzi?
    AS for the 2nd question, do you not have the capacity?
    Piekrray, give more details..
  11. Pikerray
    Pikerray Member
    All the information I have is that the Jacuzzi needs a 6amp supply for the pump and 7amp supply for the heater both can be hardwired or plug in.
  12. JP.
    JP. Screwfix Select
    When all this work is finished..how can it be signed off?
  13. Pikerray
    Pikerray Member
    £50 backhander ;)
  14. JP.
    JP. Screwfix Select
    Bit blatant Pikerray isn't it?
    I'm all for the definition of competent person..however this is not operational with respect to your posts.
  15. Knowsome
    Knowsome Member
    Well if he did complete the work properly JP couldn't he get a sparks to check it out and sign it off for a reasonable fee?
  16. JP.
    JP. Screwfix Select
    Hence the backhander Knowsome.
  17. Pikerray
    Pikerray Member
    Lighten up fella's, it was said tongue in cheek.
