Which panel pins for tongue and groove?
Discussion in 'Carpenters' Talk' started by Maxine Easey, Sep 21, 2021.
  1. Maxine Easey
    Maxine Easey New Member
    Hi all I am making a sliding shed door using a frame clad with tongue and groove. What are the best panel pins to use to attach the t&g to the frame? It's going to be exposed to the elements so I want to avoid rusting. Cheers! Max
  2. Shytot
    Shytot Active Member
  3. rogerk101
    rogerk101 Screwfix Select
    I would use screws.
    Nails will just pull out with all the cupping and movement that the wood will endure if it's exposed to the elements.
    I know ... I made that mistake once and will never do it again.
