Are there any no-no's with regard to choice of silicone for worktop joins, sink cut-outs etc. High or low modulus? Acetoxy or neutral cure? Or will any old silicone do?
I tend to use Dow Corning 584, atleast I think thats the ref no. Any good quality silicon will do, acetoxy. I tend to use any old tube ends up on cutouts and cut edges. On cutouts I would use Colorfil on speckled patterns, it helps the joint disappear, otherwise a thin application of clear or if I can get it translucent silicon. Some recommend using PVA on joints, I think it personal choice, try both methods and see which one you get on with.
