Which way to lay the membrane
Discussion in 'Landscaping and Outdoors' started by bond007, May 9, 2018.
  1. bond007
    bond007 Member
    Guys
    QUick question, the hexagonal surface area in question. Which direction to lay the membrane without much wastage.
    I Am going to cover area with 20mm gravel. Will it still require a membrane to go underneath?
    Also is 100 GSM thickness a good membrane to go for?
    Does membrane need to be pinned into the ground if gravel is going on top of it?
    Thanks
  2. KIAB
    KIAB Well-Known Member
    What's going on top of gravel.:confused:
  3. Isitreally
    Isitreally Well-Known Member
    Not sure I understand the question.?? Isn't the shape symmetrical or very close to it.
  4. bond007
    bond007 Member
    Ye 20mm gravel.. About 3 tonne
  5. KIAB
    Me neither, if he laying gravel on top, then a geotextile fabric would be a better choice than a membrane, which is plastic sheet(DPM).
  6. bond007
    bond007 Member
    Mearning horizontal, vertical or diagonal
  7. Isitreally
    KIAB likes this.
  8. bond007
    bond007 Member
  9. Isitreally
    They would stop it being caught and pulled up through the gravel, but if you put 50mm of gravel on it should hold it down.
    I would fold edges under a 100mm or so, so you don't have any frayed edges that may rip or even come up through the gravel.
  10. KIAB
  11. bond007
    bond007 Member
  12. Isitreally
    I've used 6"galvanised nails before, due to have hundreds of them from old and nothing to use them in these days. :D:D
  13. bond007
    bond007 Member
    THink I have a load of long decking screws lieing about... Prob use them too
  14. WillyEckerslike
    Don't use screws - the membrane/fabric will wrap around them as you insert them - nails just punch through and keep going.
  15. bond007
    bond007 Member
  16. KIAB
    Can't tell from photo, but if same as the Apollo HD fabric in Wickes, then it will be 105GSM & have a 10 year warrenty against rot.
    Some builder merchants do sell geotextile by the metre, a fiver or less a metre, & it's 4.5mtrs wide, so no joins.
  17. bond007
    bond007 Member
    The wikes appolo one have very bad reviews so dont really want to be getting that one if its same in screwfix.
    Who sells geotextile, will i be better off going for that?
  18. Isitreally
    Whats wrong with reveiws on SF for the actual product. ???
  19. bond007
    bond007 Member
    How would I take a wheelbarrow over a grass patch?
    Do I just put a plank of wood and wheelbarrow over it
  20. KIAB
    Push it!:D
    Seriously just lay a plank down.
