Which worktop jig for a 10mm mitre?
Discussion in 'Kitchen Fitters' Talk' started by Richard_, Jun 14, 2018.
  1. Richard_
    Richard_ Active Member
    Which worktop jig would you recommend 10mm mitres for square edged worktops?
    I see Unika have an all singing multi-surface jig to do both shallow and deep cuts. http://www.unikainnovation.co.uk/?page_id=10874
    I spoke to Routing jigs who have one in the pipeline, but not yet :(
    The contact page on Axminster's website boasts of "knowledgeable and friendly team of Experts". The chap simply thumbed through their catalogue and didn't understand the question. Underwhelming.
  2. KIAB
    KIAB Well-Known Member
    I just use biscuit jointer or router with suitable bit for cutting slots in worktop.
  3. Richard_
    They can't be directly butted because they usually have a tiny bevel on the corner, a smaller 10mm mitre gets rid of that.
  4. Richard_
  5. sospan
    sospan Well-Known Member
    if you just want a 10mm deep masons mitre, I would cut it mainly by power tool and the rest by hand
  6. Scott Green
    Scott Green Member
    I use the unika jig in the link. Available from toolstation. Never had any issues with it
    CGN likes this.
  7. kitfit1
    kitfit1 Well-Known Member
    :eek: You obviously don't do it for a living...............i hope.
  8. kitfit1
    Yep use the same jig myself. I did buy the contract one as well a couple of months ago because Toolstation had it on offer for £35 at the time................a cheep handy backup in case it's ever needed.
  9. sospan
    Year and years of experience doing it for a living and can do it very well. If you can't cut a masons mitre without using a jig, it is a pretty poor show
    especially one that is only 10mm deep like the op wanted
  10. kitfit1
    Don't be so stupid. If you do it for a living, are you telling me you cut Acrylic be hand ? i don't think so. If you do Acrylic you have to use a router and endless different jigs. If you have a router and all those jigs, why on earth would you waste your time cutting anything by hand ?
  11. Richard_
  12. CGN
    CGN Well-Known Member
    Unika from TS.
  13. metrokitchens
    metrokitchens Well-Known Member
    Just pop a bit of 18mm board behind the pin on a standard jig.
    Gregor87 likes this.
  14. seen it all before
    seen it all before Active Member
