I have, arrived today, assembled it but I have a bit left and I have no idea where it goes It's like a washer made of thick steel ~6cm in diameter with a square hole in the centre Where does it go?
I'm still lost. If i remove the bolt with the lazer then fit the washer the lazer is out of line. Is this a substitute if I remove the lazer fitted bolt?
first of all.ur metabo should have come pre assembld.bor nut washer 30mm should be on there to hold the blade in place. check manual.maybe u got spare washer by mistake.good luck
I seem to remember I had a spare washer as well, it's in a little polythene envelope, right ? I wouldn't worry about it, I never used mine and the machine works perfectly.
