I
Isitreally
Guest
That would be taken up by your hand brake adjuster. As you adjusted the brakes using the parking brake the fluid would be sucked back in.
I give up.
Please never do brake on anybody's vehicle.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Don't be a kn#b. You said the handbrake adjusts the pistons. If that were the case you would use it to adjust the pistons after a refit. The hydraulics is a closed system so any retraction or expansion of the pistons would cause the fluid to move accordingly. I've said that I'll check at the garage when I get back which I will do but in the meantime your comment about me working on my cars is unwarranted and rude. Oh, I still haven't found a ratchet in a piston. Genuinely happy to be shown otherwise and want to learn more as I've also said so you don't need to be offensive about it.I give up.
Accepted, thank you. I'm away now and this is awkward on my phone. I will read it when I can and will pick this up when I get back.Sorry unwarranted remark by myself.
Also on that vid he even says the handbrake adjusts on the pin.
The piston doesn't turn in its operation so what turns the pin?? yes the handbrake movement.
The only adjustment needed is to the handbrake the hydraulics are just that, there's no adjustment to the foot brake on a system where the handbrake is independent.
It's the same on drum brakes, the wheel cylinder pushes the shoes out to the drum, the handbrake adjusts them so they stay close to the drum, so when the handbrake is applied there's not lots of free play.
