Why does hot water freeze quicker than cold
Discussion in 'Plumbers' Talk' started by Lokkars Daisy, Jul 13, 2012.
  1. Crowsfoot
    Crowsfoot Screwfix Select
    No-one fancies having a stab at my question then
    Oh, I get it you want a clue ?
    Hot water won't freeze because it's A - T -  V -
    There you go just 3 letters to get now and as a bonus first one correct can have the prize that I won from Sam earlier on in the thread !
    Tappy,
  2. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    ...and there was me thinking that hot water won't freeze because it's....hot.
    Pffft.
  3. palavaman
    palavaman Well-Known Member
    Am I allowed to answer?
  4. joinerjohn1
    joinerjohn1 Screwfix Select
    Palava No you can't answer becuase the answer is active, and I've just won a tenner of Crowsfoot.
  5. Mr. Handyandy
    The question is active, that's for sure.
    Mr. HandyAndy - Really
  6. ilikethislady
    ilikethislady New Member
    Supercooling.
    AW
  7. Sam Spade, absolutely pure water can be super-cooled to temps well below 0oC without freezing, -40oC being typical.
    Where did I get this? Everybody knows it...
  8. joinerjohn1
    DA, pure water can be cooled to below 0 degrees C, but as soon as someone either rattles the container it's in or even looks at it a bit funny like, it will instantly freeze solid. ;)
  9. I know how it feels :(
  10. Water Systems
    Water Systems New Member
    Oh my God!!!!!
  11. sam spade
    sam spade Active Member
    To say that absolutely pure water can be super-cooled is not the same as saying that it cannot freeze.
  12. Ok, in moron-speak; it can be cooled to -40oC without it freezing.
    Not that you're a moron, of course...
  13. Spooner
    Spooner Member
    Here's a wee tip from a Master Plumber;
    If you're freezing pipes; spit on the pipe next to where you're trying to make the ice block, a right big groger mind!!  If your groger freezes, then you're water in the pipe will be frozen........;)
    Job done.
  14. Water Systems
    Hey Todger!  Have you given up on DIY Doughnuts? What happened?
  15. joinerjohn1
    He was driven away by doubtful advice , about Atag and Intergas boilers, given by someone called Walter.
  16. Spooner
    Spooner Member
    Eh, lets just say they no longer require my services on DIYdoughnuts............
    How you doing WS?? Still selling the sludge buckets??
