Why does my shower have no not water?
Discussion in 'Plumbers' Talk' started by Mackenzie08908, Feb 5, 2021.
  1. Mackenzie08908
    Mackenzie08908 New Member
    Hello,
    Looking for some advice on my shower. It was working fine, but since yesterday there is no cold water coming out of the shower or bath, the cold tap turns but nothing comes out. The hot tap is coming out scalding hot and at full pressure. After about 10 minutes it goes cold and then back to hot again.
    Any advice?
    this happened before for weeks and randomly went away by the time my landlord arrived to look at it so just want to see what the problem could be. Shower copy.jpg Tap copy.jpg
  2. terrymac
    terrymac Screwfix Select
    If no cold water whatsoever comes out the tap ,the taps cold valve is stuck closed.
    The reason your hot tap is scalding hot for ten minutes ,and then goes cold needs on site investigation. What provides your hot water ,is it a combi boiler ,or do you have a hot water cylinder ,or something else ?
