Wickes shower door?
Discussion in 'Plumbers' Talk' started by dvddvd, Apr 15, 2019.
  1. dvddvd
    dvddvd Well-Known Member
    Hi all, I'm looking for a framed shower door to fit an opening of 725mm.
    The last one I bought from ebay and it was classed as a 760mm door but you could adjust it up to 20mm each side so it would fit an opening from 720-760mm
    I need one for tomorrow and Wickes have this one
    https://www.wickes.co.uk/Wickes-Pivot-Door-Only-Chrome-760-mm/p/161390
    But all it says is 760mm wide and you can adjust it by 20mm for uneven walls? but no min or max sizes?
    Will it be the same as the ebay one where you can adjust by 20mm each side and it will fit a 720mm hole ?
    thanks
  2. spirits are real 2016
    spirits are real 2016 Active Member
    it says on the description adjustment by 20 mm on the width.
  3. dvddvd
    For uneven walls, is that both sides? Or 10mm each side? It just looks like the same one I bought from eBay but the wickes one has a not very detailed description ?
  4. dvddvd
    Just fitted it, it was 20mm adjustment each side. So fits opening 720mm to 760mm
    WillyEckerslike and CGN like this.
