Wickes Silicone Sealant
Discussion in 'Plumbers' Talk' started by Glad its Friday, Sep 22, 2008.
  1. Glad its Friday
    Glad its Friday Active Member
    Just finishing off a bathroom job and picked up some of the above when a found I didn't have any of my usual Dow Corning 785 on the van. Disaster! Just had to take off the shower surround as I couldn't stop the leaks and found that the Wickes stuff just hadn't gone off properly (yes I did leave it 24 hours). Only bonus was that it cleaned off (worryingly) easily.
    Anyone else used this stuff recently and had the same trouble? Thinking of buying some....be careful.
  2. fil0
    fil0 New Member
    Yes, wickes silicone sealant is totally cr*p (as are many of their glues, paints etc. - have used it twice - is too soft and takes weeks (yes weeks!) to set. Will never use it again - I always use Unibond sealants
  3. Captain Leaky
    Captain Leaky New Member
    Dow is the best, Unibond is OK too if you can't get Dow. Always avoid anything own label.
  4. Glad its Friday
    Cheers guys - had a tube of Dow on the van but my apprenti threw it with the empty tube. What can you do?!
    Be aware everyone, the Wickes silicon is no good, don't even think of using it.
  5. bathstyle
    bathstyle Active Member
    The Wickes stuff used to be very good. I'm not sure when it changed but it is dreaful now, very runny, impossible to get it looking good
  6. Cornish Crofter
    Cornish Crofter Active Member
    Wickes stuff is terrible - and that includes their whole range IMO.
    I used their tile adhesive once - that was enough. I got called back to that job to replace tiles 3 weeks after they went up.
    I ended up lining the wall with hardibacker and re tiling, which the customer paid for anyway. To be fair it was in a new shower cubicle, but the adhesive did say it was waterproof.
    I never chuck anything away but I did this time.
    No I'll only use BAL products in a bathroom. I'll use a wider range in a kitchen, but not Wickes!
  7. G Brown
    G Brown New Member
    Wickes = cheap rubbish, worse than B&Q now and about as bad as Homebase.
    AVOID!
  8. Cornish Crofter
    ......and that pretty much speaks for the whole range that they sell.
  9. G Brown
    G Brown New Member
    Shame, they used to be quite good until Travis Perkins took them over, nowadays they are useless.
  10. Cornish Crofter
    The thing is I've used Travis Perkins sealant and tile adhesive and have been very pleased with it.
    I'm now using the Dow Corning 785 from here.
