Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Get the fitters back, the Windows aren't locked into the bay poles properly and is a point for water ingress. Sloppy.
Well it's not difficult in the first instance but now the glass is in it involves removing it and any cover moulds, cills, anything restricting the window frame from moving and tapping the frame into the pole to lock it into place. Though the builder will probably try to silicone over the gap or fit a trim to cover it to avoid doing the work I listed above.
The bay pole is probably out of plumb and the fitter couldn't get the last window to seat correctly.
