Window placement
Discussion in 'Carpenters' Talk' started by Rodgeramjet, Jun 12, 2018.
  1. Rodgeramjet
    Rodgeramjet New Member
    Hi I am building a single block shed with peers 50 mm cavity and 3x2 inner skin with osb face where is the best point to fit windows? Directly behind the block,?between the block or between timber stud.
    Thanks
  2. AlvyChippy
    AlvyChippy Active Member
    22mm of the front "face" line...
  3. Rodgeramjet
    Cheers Alvy can I ask if there is a reason for this 22mm from front of block? Is it to accommodate a corner bead for dashing?
  4. AlvyChippy
    Most "optimal" position to the most of the variants ;)
