Wellwisher
Screwfix Select
As you are not a sparks you won’t understand.Why not?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Doing the correct thing is often more difficult than bodging.You must like making life difficult
Plugging an item in is not a bodgeDoing the correct thing is often more difficult than bodging.
It is bad practice.That’s your subjective view, not a Reg requirement. What OP is proposing is acceptable.
It is bad practice.
Because 13a sockets are designed for loads up to 13a. Putting a 13a load on a lighting circuit will plunge you into darkness.I didn't say I wasn't a spark, I said I didn't work as a spark. So please explain. I will understand.
Why is it bad practice to fit sockets to a lighting ctt?
If he was saying can I install a socket off the lighting circuit for a kettle then yes, but a few lights?? Don't think soBecause 13a sockets are designed for loads up to 13a. Putting a 13a load on a lighting circuit will plunge you into darkness.
A 3a fuse has no discrimination against a 6a MCB especially when that MCB is already loaded with lights around the house.Put a 3a fuse in plug.
People tend unplug lights when they have something else they want to use.If he was saying can I install a socket off the lighting circuit for a kettle then yes, but a few lights?? Don't think so
On top of a kitchen cupboard?People tend unplug lights when they have something else they want to use.
Anyway someone about to plug in a large load is not going to stop and change the fuse for one he knows will fail.
Good place to plug in a fan heater pointing down. There are other examples.On top of a kitchen cupboard?
Lol, I give up.
A 6 a MCB already loaded by lights around the house leaves a margin less than 6. <6a/2 is <3a.The regs say to discriminate you need the fusing factors of the fuses to be about half of each other. 6a / 2 is 3a. The time current characters will show this. Have you found a anomaly in the laws of physics?
Rubbish. If the circuit is loaded to 4 amps say there only 2 amps available. 2 is less than 3.So what? The point of failure will be in the 3a fuse regardless of the loading on the ctt. Do you understand how discrimination works?
