Wellwisher
Screwfix Select
People don’t read labels.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
You could always run a ring for your lighting circuit, then you can plug what you like in,If he was saying can I install a socket off the lighting circuit for a kettle then yes, but a few lights?? Don't think so
Good place to plug in a fan heater pointing down. There are other examples.
Yea I often use the plug above the kitchen cupboards to plug in my welder.
I have finally realised that @Wellwisher is toying with us all.
A fan heater on top of a wall cupboard in a kitchen, pointing down. That's funny!
Assuming you are still around, cutting through three pages of trash, your original idea of the socket on top of the cupboards seems like the best solution.I have led strips with transformer plugs which I need to connect to the lighting circuit so the light switch can control them. Is it ok if I add a 13A sockets above each cabinet to plug transformer plugs into?
I personally can’t see anyone climbing up onto the cupboards to make a cup of tea!![]()
Wrong. It is bad practice and the worst solution. The correct power supplies into a JB is the best solution.Assuming you are still around, cutting through three pages of trash, your original idea of the socket on top of the cupboards seems like the best solution.
How do you fit wall warts, which the original poster has, into a junction box.The correct power supplies into a JB is the best solution.
Why didn't you post that 48 posts ago
I said THE CORRECT POWER SUPPLIES. Wall watts are not the correct power supplies to use in this case.How do you fit wall warts, which the original poster has, into a junction box.
Think wellwisher is out of his box, some of the things he comes out with.have to think out of the box sometimes
That is what came with his lights which the thread is about.Wall watts are not the correct power supplies to use in this case.
Clearly wrong. 7671 can mark a mistake just like anyone else.
