Wellwisher
Screwfix Select
Indeed. If they came with wall warts they are clearly designed to plug into power circuits not lighting circuits.That is what came with his lights which the thread is about.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Shows us the reg saying they can't. Bazza just posted the reg saying they canIf they came with wall warts they are clearly designed to plug into power circuits not lighting circuits.
No they are not. They are designed to plug into BS1363 sockets. Everyone else’s standard is BS7671, which does not define the type of circuit a BS1363 socket has to be connected to, the only mention is Bazza-spark’s quote in post #51, although how a simple question that just required a single word of “yes” got to 51 posts is beyond me.Indeed. If they came with wall warts they are clearly designed to plug into power circuits not lighting circuits.
Why don’t you think instead of insulting those that do? Anyone with half a brain cell can see that putting a 13a load on a 6a circuit shared with lights is not a good idea.Box ? more like a care home if you ask me.
You know why lol.Why didn't you post that 48 posts ago![]()
Your evidence to support this being?Clearly wrong. 7671 can mark a mistake just like anyone else.
A good example in @DBCDIY post just 3 above.Your evidence to support this being?
No, it isn't. That is a multiblock extension. The OP is referring to a 13A socket.A good example in @DBCDIY post just 3 above.
It is an example of BS regs making a mistake.No, it isn't. That is a multiblock extension. The OP is referring to a 13A socket.
Try again, no chocolate bar this time.
Like cooking steak![]()
I like mine rare.
I would still agree that bs1363-2 sox are allowed on lighting ctts but I'm not convinced that Reg 559.5.1 specifically allows this. The reg is chapter 55 in the 559 LUMINAIRES AND LIGHTING INSTALLATIONS which applies to the selection and erection of luminaires and lighting installations intended to be part of the fixed installation, so I would say a socket can only be fitted to a lighting ctt. IF the socket is to be used as a lighting point. In other words, the expectation is that only luminaires and lighting installations are going to be plugged into it.
Surely putting clear sticker on it will indicate its purpose and maybe a warning tag, its how I've done the few I have, I get where your coming from though as in a socket inside a suspended ceiling isn't accessible by say a cleaner who wants to plug in a vacuum cleaner, however on top of a wall cupboard would also make it inaccessible.
No it isn't. It's an example of a poorly made product, nothing to do with 7671.It is an example of BS regs making a mistake.
Wouldn't expect you to agree. Anything for an argument aren't you.Yea I agree with a sticker that's fine and there is no specific reg that doesn't allow a socket to be fitted to a lights ctt. but I'm not convinced that 559.5.1 would allow sox to be fitted specifically to a lighting ctt. for anything other except to power lights, except in conditions as you say.
I mean if it really bothers then fit a 3a fcu and feed a sox off that.
Somebody that says sox for sockets and ctt for circuit must be right - not.
