Wiring a relay switch - advice needed
Discussion in 'Electricians' Talk' started by gajones, Dec 4, 2019.
  1. gajones
    gajones New Member
    I have a Zigbee relay switch that I wish to use to control the under cabinet lights in my kitchen. I am hesitant to connect it as I am unclear how to wire it correctly. Does the "L Output" need to be connected to anything? Do I leave the earth where it is? Any help much appreciated. Hopefully the photo will make everything clear.
    [​IMG]
  2. Philip Hyde
    Philip Hyde Active Member
  3. peter palmer
    peter palmer Super Member
    Whats the wire on the other end with a big red x on it for, is it a volt free contact or something.
  4. gajones
    gajones New Member
    I presume this is where the wires from the LED lights' power supply should be connected.
    [​IMG]
    [​IMG]
  5. Philip Hyde
    No I think that is for a low voltage switch or link instead of using the remote. It doesn't have a low voltage output only mains
  6. peter palmer
    Maybe some kind of override, wire them to a push switch and it might operate the relay.
  7. gajones
    gajones New Member
    ok. so should the Zigbee go before or after the LED power supply?
  8. Philip Hyde
    Before. The 2 brown off t and e go in L 3 blues into N and brown off flex in to L output. I would use a Wago connector for the neutrals and just take one into the relay
  9. gajones
    gajones New Member
    thanks for all the help - it works!
