Wiring an extra outbuilding
Discussion in 'Electricians' Talk' started by Pminnie, Apr 21, 2010.
  1. Pminnie
    Pminnie New Member
    I am building another outbuilding to the rear of my home, I do have a garage which is fed by a 6mmsq cable from the CU in the house. the length of cable is approx 18m and is protected by a 65mA RCD in the CU. The new building is set further back and the length of cable from my existing garage to the new building is approx 33m. The purpose of the new build is for my son and his band to practice and record their music, they will have the usual musical instruments and amps. will 6mmsq T&E be ok or will I need to replace the cable rigt to the CU in the house to something heavier and should I use a 30mA RCD in the studio.
  2. spark&half
    spark&half Active Member
    65ma rcd??? Are you sure?
  3. spark&half
    How much electric do you use in your garage?
  4. 999
    999 New Member
    must b a industrial one like
    x
  5. Pminnie
    Pminnie New Member
    Sorry its a 63A RCCB and in the garage I have a 200ltr compressor 3hp motor and there is nothing running just what ever tools I use and 4 florescent lights.
  6. 999
    999 New Member
    ah bless
    x
  7. 999
    999 New Member
    but its already protected is it not?
    and apart from lights and sockets will the outbuilding need any heating?
    x
  8. Pminnie
    Pminnie New Member
    No the heating will be oil fired, and I was going to use the RCD so as if there was a trip There would still be lights in the studio.
  9. 999
    999 New Member
    4 give if im wrong but didn't you say the supply is fed by a 63A RCCB
    999
  10. Pminnie
    Pminnie New Member
    Thats correct but in the garage if there is a trip in the house the garage goes black, & I would like if I still had lights more so in the studio
  11. 999
    999 New Member
    perhaps the rcd protection shud be local rather than supplying
    x
  12. Pminnie
    Pminnie New Member
    Yes thats what I thought but what about the supply cable to the studio will 6mmsq be ok at that lenght ?
  13. Pminnie
    Pminnie New Member
    sorry meant length
  14. 999
    999 New Member
    there r many other other issues here 1 is sure u can work those out 4 1s self
    999
  15. Pminnie
    Pminnie New Member
    Not much help but thanks anyway
  16. 999
    999 New Member
    this work shud be done by a qualified electrician 4 many reasons like UP
    x
  17. Removed 4
    Removed 4 New Member
    A 6mm cable for that extended run from the garage to the studio will be adequate, for 'band practice" etc. A 6mm SWA XL cable will allow you around 5kW.
    You mentioned using 6mm T&E? Do you think that's wise?
    Lucia.
  18. Pminnie
    Pminnie New Member
    Thanks! I am open to suggestions I think 5kW would be good perfect.
  19. Pminnie
    Pminnie New Member
    I am going to run the cable underground in a red electric conduit pipe
  20. Removed 4
    I hope you don't mean you're going to run <u>T&E</u> underground, duct or not!
    Lucia.
