hi guys. can anyone help me please. im.having a new kitchen fitted and I've come accros a problem which is doing my head in. can i wire the hob and oven together?? I've heard you can and someone at work says that it will fry my appliances. I've just ordered this https://www.superlecdirect.com/p-pr...MIhOqv8ZGE1wIVKBbTCh0UuQRMEAQYASABEgLrl_D_BwE I can wire it myself but don't want to blow my new appliances. I've current bought a Neff induction Hob and Neff electric Oven. here's the spec if that helps. HOB Features 4 zone induction hob Variable 17-stage power settings for each zone 2 stage residual heat indicators Control panel lock QuickStart function ReStart function Boost setting for all zones Automatic pan recognition 4.6kW power output (20A); current management options for 16A, 13A or 10A connection Safety cut out facility Control panel lock Timer with automatic shut off for all zones LED timer for each zone with switch off function and acoustic signal Design: 592 mm wide 60 cm width Bevelled front edge Technical information Installation measurements: 560 mmx490 mm Length wire connection: 110 cm 4.6kW power output (20A); current management options for 16A, 13A or 10A connection Min. worktop thickness: 30 mm Output 4600 W OVEN Product Video Over 800 views in 24 hrs £733.00 Save £16.99 Was £749.99 (from 19/09/2017 to 20/10/2017) Compare prices FREE delivery available More info Collection not available Let's show you Delivery dates and prices All local to you Product features Capacity: 71 litres Oven type: Multifunction Pyrolytic cleaning Energy rating: A Two year manufacturer’s guarantee DISCOUNT CODE - £50 off the marked price. Enter code BUILT50 at checkout. Also available in store. Hurry, ends soon! More info HALF PRICE INSTALLATION - Select installation at checkout. Discount already applied. Also available in store. Limited time only More info DISCOUNT CODE - Save £50 off your order when you spend over £500 on two or more large kitchen appliances. Enter code COOK500 at checkout. Also available in store. Hurry, ends soon! More info Claim a prepaid grocery card worth £100 when you purchase this product More info Product fiche Read 95 customer reviews Ask an owner With expert service from We can install this product for only £44.95More info Get your old product removed & recycled for £15.00More info Monthly protection of your NEFF B57CR22N0B Slide & Hide Electric Oven - Stainless Steel for only £3.99 More info Product information The built-in Neff B57CR22N0B Slide & Hide Electric Oven is spacious and packed with plenty of different functions that allow you to cook the way you want. More precise cooking Using CircoTherm technology with a powerful fan as its main cooking function, the Neff B57CR22N0B offers extremely balanced heat distribution, giving you food that's evenly cooked in less time. Among its 12 functions, Hot Air Eco combines hot air with steam for tantalising browning and crisping for all kinds of ingredients. Use the Top/Bottom Heat setting for a conventional approach that's great for baking scones, pastries and other treats. Integrated grill and specialist functions A full-width grill gives you more ways to prepare food in your Neff B57CR22N0B Oven, from meat and fish to vegetables, snacks desserts. It's variable, so you can use it at half-width to accommodate smaller portions. The Hot Air Grilling function cooks your ingredients thoroughly inside and out while crisping the top, so it's especially good for meat and pork dishes. You'll even be able to prove yeast dough in the oven, improving the texture and quality of pastries like cakes and breads. Discreet and easy to clean A Slide&Hide door fully retracts under the NeffB57CR22N0B, making loading and unloading easier and safer by taking up less space in front of the oven. Pyrolytic liners in the oven allow the appliance to effectively clean itself by burning away any deposits from roasting, baking and grilling. It's a simple matter to wipe or sweep away any residue to maintain a beautifully clean interior. Cook well with the Neff B57CR22N0B Slide & Hide Electric Oven. Specification Technical specifications for NEFF B57CR22N0B Slide & Hide Electric Oven - Stainless Steel OVERVIEW Type Built-in single oven Fuel Electric CONTROLS Timer type Programmable Cooking functions 12 oven functions, including: - Braising - Bread Baking - Bottom heat - CircoTherm - Conventional heat ECO - Dough proving - Hotair Eco - Pizza setting - Top/bottom heat Display type LED display Control type Buttons OVENS Oven type Multifunction Energy rating A Energy consumption 0.69 kWh Number of cavities 1 Capacity 71 litres Size Large Viewing window Single-glazed Interior light Yes Type of cleaning Pyrolytic GRILL Grill type Integrated Grill features - Hot air grilling - Full surface grill - Half width grill GENERAL Colour Stainless steel Bar handles Yes Electrical installation This product requires hardwiring to a 16 Amp fuse and should be installed by a qualified engineer, such as one of our Knowhow experts. Power supply 16 amp
Hi Lee Don't listen to "someone at work". What do they know? Yes, you can install both appliances on to the dual outlet plate, that's why they manufacture dual outlet plates. Have you asked an electrician to check your kitchen layout against the existing accessory positions? Might be worth asking one. Good luck
Team 'Knowhow' more like Team 'Knowfa'. Anyway, apart from that, congratulations on buying a decent oven and hob. Yes, both the oven and hob may share the same cooker control unit provided that neither is more than 2 metres away from the cooker control unit. If you have an existing cooker circuit with a cooker control unit connected, all you need to do is run a 6mm or 10mm cable (depends on the existing cable and CB size) from the control unit to the hob, and another to the oven, simple as that. You may need to use supplementary heat resistant sleeving on the cable insulation at the warm end in the oven and hob, be guided by the manufactures instructions. Oh, yes, your mate at work would not make an electrician, ignore him you won't 'blow' the appliances unless you have a 415 volt 3 phase supply to connect them to. Perhaps he should apply to join "Team Knowhow".
Yes, if you look back at other posts on this subject you will see similar questions and answers. Others will confirm.
Hold on there pardner - There are two bits of ESSENTIAL information that NOBODY has asked. Everybody is guessing that you already have an existing oven/cooker supply to the kitchen? Do you? This will need to be on its own separate circuit from the consumer unit. If it is, we need to know how many amps is the MCB protecting that circuit. It will say something like B32 on it. Post a photo if you aren't sure..
I've just removed a gas top and electric oven. but now I'm installing 2 electric appliances. electric Hob and separate oven I've ordered a twin box to replace the singe so I can wire them both in
Each of those switches should have a label saying what they control. Sometimes it's inside the cover that seems to have been removed.
I'm going to guess the oven is 32A...2x6A on the left which are two lighting ccts. 1x16A, boiler/immersion or some such. Then 3x32A (can't see right hand side)..ground and 1st floor final rings and oven. But perhaps I should stop making it up.
