what if the thermostat cable is buried into the plaster and is 230V, is RCD protection required or not ? even if its till connected via a plug.
That's an interesting point Steve, I suppose if the stat cable was installed post 17th. rcd would be required, even though it's supplied from a plug?
bs7671 ends with the plug - there is no reason to stop anyone supplying a shed via a socket thus avoiding 7671 and part p altogether.
Yes Coloumb, I suppose if something is connected by a plug it isn't considered fixed wiring, even if it is concealed/chased into a wall.
*** rcds you kids commando sockets are made to a certain size colour etc to match the rating wtf cheers
I cannot see anything wrong with wiring a boiler to a 3 pin plug. Atleast that way the poor old lady can still plug the boiler into a different circuit if need be So why do many people insist on using a fixed spur which isn't easily accessible to a non-spark??? Also why specify an unswitched socket???
