Wiring for Nest Heatlink replacing Honeywell T6360B
Discussion in 'Electricians' Talk' started by Sascha, Aug 1, 2020.
  1. Sascha
    Sascha New Member
    Hi there - this is the first time i’m posting so please be gentle with me. i’ve received a nest and need to wire it replacing my old Honeywell Thermostat T6360B. the wiring is not straightforward as the honeywell does not seem to have “C” and “N0” wires. i’ve attached sone pics of the current thermostat and wonder which of the wires go where in the Nest?
    thanks for your help
  2. METRO MARK
    METRO MARK Active Member
    Hi for basic boiler switching
    Switch power off to boiler before handling wires
    OLD THERMOSTAT..........NEW THING
    1 BROWN ---------------C
    3 BLACK ----------------N/O
  3. Sascha
    Sascha New Member
    great - many thanks! will try out now
  4. METRO MARK
    OK
    AS I said turn power off as the Brown wire will probably be LIVE...!
  5. Mike83
    Mike83 Screwfix Select
    You’ll also need to keep your old heating programmer turned on for the stat to work
  6. Sascha
    Sascha New Member
    thanks - all considered and working well. thanks Mark and Mike
