Wiring new cooker
Discussion in 'Kitchen Fitters' Talk' started by Whiteeagle, Nov 26, 2018.
  1. Whiteeagle
    Whiteeagle New Member
    Hi all, hope you beed doing well:)
    I got my new cooker and I'm not sure how to wire it to the mail.
    There are 220v and 240v diagram
    Can anyone advice please. I have added some pictures... my main box shows 230v
    Thank you in advance
    AJ
  2. Rulland
    Rulland Well-Known Member
    220-240v:)
  3. RolandK
    RolandK Active Member
    It means 220 to 240 volts. 240 is the nominal voltage whereas actual is 230 plus or minus a bit!
  4. RolandK
    I still find your profile pic somewhat distracting!
    Rulland likes this.
  5. Whiteeagle
    Hey Rulland.
    So the live to left Live Neutral to 3rd Neutral and ground right?
    Will 6mm are thick enough?
  6. Rulland
    Yep, live to either of the two, neutral to any of the three, cable size depends on load, allowing for any diversity, 6mm is the most common used though.
  7. Whiteeagle
    Cool ,I just checked and the 6mm cabke can handle 38amps 9120w but in the manual it said the cooker are 11300w . So do I need thicker one like 10mm ?
  8. kitfit1
    kitfit1 Well-Known Member
    If you don't know the answer to this question, you really do need to be letting an electrician sort this out for you.
  9. Dam0n
    Dam0n Active Member
    Diversity can be applied as it's a cooker. Google it. I agree with Kitfit though and think you should get a sparky in to sort it out.
  10. Whiteeagle
    I got a cable and it should be 10mm one as I asked in shop but on the cable it said BS6004 6242y 2x4+1.5mm it doesn't seem to be 10mm ?
  11. Dam0n
    Dam0n Active Member
    if it's 10mm itll be like a piece of rope.
  12. Whiteeagle
    Found it thus is 4mm one lol good sale, going back to shop. I havent mentioned my cooker are 11300w so I will need 10mm one as 6mm can deal only under 10000w please confirm
  13. Whiteeagle
    Specifications
  14. chippie244
    chippie244 Well-Known Member
    As said diversity brings you below 10Kw.
  15. Whiteeagle
    Thank you all :) for your time and help. As my unit in full power can go high to 11300w I will wire it with 10mm cable it will not harm but always secure.
  16. chippie244
    Why did you bother to ask for advice if you are just going to ignore it?
  17. Whiteeagle
    What do you mean chippie? By installing 10mm will do something wrong?
  18. chippie244
    No, everybody told you 6mm was fine and what you decided to do was use 10mm, it's up to you but it will be harder and cost more money.
    Why ask for advice and then ignore it?
  19. Whiteeagle
    you are right mate. And thank you .
  20. barbaricduck
    barbaricduck Member
    Got that back to front there Roland. 230+/- is the nominal EU carp, 240 ish is the actual in the UK generally, due to the transformer windings.
