Wood Cutting Blade for 4" Angle Grinder
Discussion in 'Carpenters' Talk' started by Axel, Oct 25, 2010.
  1. Axel
    Axel New Member
    Hi,
    Is there such a thing as a wood cutting blade that will fit a 4" angle grinder? I have seen the Bosch all rounder tool with an all purpose blade, but I already have a 4" angle grinder that I rarely use and wonder if I can get a similar blade that will fit the spindle.
    Axel
  2. Guest
    [Edited by: admin]
    [Edited by: admin]
  3. Captain Leaky
    Captain Leaky New Member
    It would be extremely dangerous and liable to kick back violently. The Multipurpose tools ( like the Fein) oscillate they do not spin at high speed.
  4. There are now multi purpose diamond blades that will cut timber, however as far as I know they are only for 4"1/2 angle grinders.
  5. Guest
    I only put up ONE WORD and i've been zapped twice
  6. Axel
    Axel New Member
    I will check the size, it could be 4 1/2". Can you tell me where to find one?
    Axel
  7. agency worker
    agency worker New Member
    Hi! "NEVER" put a wood blade in a angle grinder."YOU" have be warned!!!!!
  8. joinerjohn
    joinerjohn New Member
    Unbelievably, there is such a thing. Very popular in the States with woodcarvers. Here's a UK supplier of one such beast
    Great for losing the odd finger etc
    [Edited by: admin]
  9. audievo
    audievo New Member
    Yep, it is quite a lethal beast, I know I used to use one.
    Blades
    You can get a proper undercut saw too
    Safer but not cheap!
    [Edited by: admin]
  10. wiggy
    wiggy Screwfix Select
    I have used one of these on occasion, but hold on tight,
    what is it for ?
    [Edited by: admin]
  11. big all
    big all Screwfix Select
    a member off the diy not forum was killed by such a "conversion "when it got away from him and cut deep into his neck
    big all
    [Edited by: admin]
  12. G Brown
    G Brown New Member
    Very very dangerous!
  13. If you chose to go with this dangerous practice after reading Audi's link you must be barmy.
  14. joinerjohn
    Too late... Admin have deleted the links,,,, Even though Screwfox don't sell anything like them.
  15. dunc dunc
    dunc dunc New Member
    Most biscuit jointers have the kind of blade you are looking for. In fact the jointer itself is often mcuh the same as a grinder.
  16. big all
  17. audievo
    audievo New Member
    The roberts cutter has a saftey cover, spring loaded, if it jumps off the job it pretty much closes.
    Also the balde rarely comes up against anything that gives it any kick, it flys through nails in skirting and arcs, bits of stone brick etc no problem.
  18. Unit 1
    Unit 1 Member
    If I remember rightly there was a product called Arbor Tec for wood sculpting, I presume you would have to buy the tool though.
