Wood fibre board underlay.. Tape? If so, which tape?
Discussion in 'Carpenters' Talk' started by doing_it_myself, Apr 15, 2020.
  1. doing_it_myself
    doing_it_myself New Member
    Hi
    I am about to lay some laminate flooring for the first time over wooden loft boards. I have 8mm laminate and 5mm wood fibre board underlay.
    After laying the underlay down, do I need to tape the pieces together?
    If so, would I need special vapour barrier tape or will regular masking tape or gaffer tape do?
    Quite a few different opinions out there, just need some clarification!
    Thanks
  2. Jord86
    Jord86 Screwfix Select
    Regular gaffer tape will do.
    doing_it_myself likes this.
  3. doing_it_myself
    Ace, thank you. I have some of that somewhere, so no need to go hunting for vapour tape. Cheers!
  4. doing_it_myself
    Would regular masking tape be ok to use as well?
