Wooden Facia board million dollar question
Discussion in 'Carpenters' Talk' started by Van Haven, Jul 23, 2008.
  1. Van Haven
    Van Haven New Member
    Does anone have the answer to the million dollar question....does anyone know where to get decent, treated wooden fascia, size is approx 150mm x 20mm in about 6m length. All anyone seems to sell id uPVC and i'm not interested in that!
  2. blueassedfly!
    blueassedfly! New Member
    smiths timber benfleet essex but theyll only do you a 5 metr length, and theyll presure treat it for you!
  3. cabinet
    cabinet New Member
    Would it be possible to use pre-treated decking boards. The reason why I ask I have noticed the some are smooth on the on the underside, but I am not sure what sizes they come in. The one in the link as a finished size of 27 x 144.
  4. dirtydeeds
    dirtydeeds New Member
    no, is the short answer
    the long answer
    most fascia board is 19mm finished, 27mm would bring the fasia face forward
    that shoves the gutter forward such that there is insuffient overhang from the tiles into the gutter
    to maintain the overhang each rafter foot would have to be cut back
  5. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    It would be only 7-8mm difference.
    I would not use decking boards. They would be prone to cupping, especially as only being fixed into end-grain rafters.
    But a timber of the original size, treated, would be best, and as said, timber yard.
    Mr. Handyandy - really
  6. chip off the block
    chip off the block New Member
    since when has thicker timber been more prone to cupping????
    if I knew where you lived *
    [Edited by: admin]
  7. cabinet
    cabinet New Member
    Puting your hand on our heart would 7-8mm increase in the thickness of the fascia board give that much of a problem?
  8. Mr. Handyandy
    cupping????
    It's the way it's cut, and those grooves you know. Allowing the flat side to expand and with less resistance on the grooved side, they are ALWAYS going to cup.
    [Edited by: admin]
  9. dirtydeeds
    hatred for handyandy? .........leading to murder
    it seems a "little" excessive
    an anger management course may be the way forward
    as for the 7/8mm difference. it isnt the point
    the point im making is that decking made for decking
    ................. not fascia
    and the grooving in decking is not to prevent cupping
    its cosmetic
  10. cabinet
    cabinet New Member
    I don’t understand; how come you can’t use decking for fascia board, those that did would they be publicly flogged ? At the end of the day both are produced from timber the only difference is one is a little thicker and the name and I ask my self what’s in a name.
    The grove to hold the soft board can be made with a suitable size router, can it not?
    Its only modern fascia that as a thickness of 19-20mm in days of old fascia had a finished thickness of 22, 25, 30, and even 38mmm.
    Some times I think we need to think out side the box.
  11. Mr Mike
    Mr Mike New Member
    "if I knew where you lived *"
    Are you one of those 'feral youths' they keep banging on about on the news ? :)
    [Edited by: admin]
  12. busy builder
    busy builder New Member
    Back to topic....
    Some up here use T & G boards. Actually look quite nice when stained.
  13. Mr. Handyandy
    cupping
    its cosmetic
    Quite right. Bit not only cosmetic, it gives somewhere for water to lie beneath the walking surface, aiding grip.
    For those others, think on how you might treat(WITH A SAW) a piece of timber to aid bending ?
  14. barbaricduck
    barbaricduck Active Member
    I am with Mr HandyAndy on this one. I think the trouble is that a lot of people speak without thinking first. It has caused war's in the past ya know.... Or maybe they do not possess the intelligence to think a simple concept through. Consider the testicles, and surface area's. And heat sinks. THINK!!!
  15. Biffo
    Biffo Member
    the thickness is not a problem ,when existing fascia is overboarded ,10 mm fasciaboard
    you can use a eps system which slides up the tiles/slates then locks into the gutter .
    or use 9" damp to do the same
  16. Biffo
    Biffo Member
