woodgrain doors
Discussion in 'Carpenters' Talk' started by made2fail, Mar 28, 2010.
  1. made2fail
    made2fail New Member
    can anyone advise me please as to where I can purchase a wood grain colonial door to fit a raised airing cupboard,not quite sure on the size as don't get the new house till tuesday,would imagine approx 1m in depth
    thanks in advance mb
  2. hallbeck
    hallbeck New Member
    B & Q
    Wickes
    Homebase
    Jewsons
    Travis Perkins
    Howdens
    Magnet
    MKM
    Buildbase
    or any local DIY store or builders merchant!
  3. made2fail
    thanks for the reply hallbeck,i've looked online & can only see full size doors,i'll have to call in at my local stores & have a word at the trade counters.
    mb
  4. chippie244
    chippie244 Super Member
    If it really is a metre wide, I presume you meant width not depth, you're going to have problems unless you can get a disabled access door wide enough, but I doubt that.
  5. made2fail
    i did mean 1 metre in depth,its an airing cupboard in a bedroom, over the stairs so only has a half depth door on it
  6. flyingscotsman
    flyingscotsman New Member
    Do you mean height?
  7. made2fail
    yes ok lets say height, can somebody please advise of a supplier
  8. Binfield Carpenter
    Binfield Carpenter New Member
    Virtually no chance of finding a half height door. Just get one of the correct width and cut it down to the height you need.
    If it is a pressed panel (i.e. hollow) you will need to work out where to cut to get a sensible looking result and you will fit a new head and/or foot.
  9. flyingscotsman
    Yes, lets say height because that`s the proper terminology. Buy a door and halve it.
  10. chippie244
    You're an engineer and don't know the difference between height, width and depth :(
  11. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Steady on. If it is coming down from the ceiling, then 'depth' may well be a good description, as normal doors are considered to be measure/estimated from the 'floor' up.
    If there were no door there, the wall might well be described as the 'depth' from ceiling to lowest part.
    Just saying.
    Mr. HandyAndy - Really
  12. chippie244
    A door is a separate solid shape and has a height = top to bottom, a width = side to side and a depth = front to back.
  13. flyingscotsman
    You wouldn`t be the O.P. would you mandy, with a little nom de plume. :)
  14. Mr. Handyandy
    Height = Bottom to Top.
  15. Mr. Handyandy
    Depth = downward, backward or inward.
  16. chippie244
    It's a door not a swimming pool you cretin.
  17. flyingscotsman
    So Bandymandy, every chippie is wrong, you are right. As we are on the CARPENTERS forum, I will ask. Does any time served carpenter on here, when measuring a door, refer to that particular measurement, as depth. ( Why am I even bothering with this clown?)
  18. flyingscotsman
    I suppose I could start using "bandyspeak"...Depth...wideness...thickness. :)
  19. joinerjohn
    joinerjohn New Member
    I'm after a 1m depth door for the kitchen. At least it'll keep er indoors firmly in there. ;)
  20. chippie244
    Try Fort Knox :^O
