Worcester 24cdi no hot water
Discussion in 'Plumbers' Talk' started by macca31, May 13, 2018.
  1. macca31
    macca31 New Member
    So today I have no hot water the heating side is fine. I have a Worcester 24cdi combi.
    So after a bit of advice that it’s probably the diaphragm on the diverter valve I set about replacing it. 8 hrs later and what a b***h of a job that was! Anyway no leaks so I power up and still no hot water!
    So starting to think it could be the micro switch on the diverter valve. Should I heat it click if it’s ok??
    Any help appreciated
  2. Dave does Gas
    Dave does Gas Well-Known Member
    If you did it yourself did you put the diaphram in the right way round, common error
  3. macca31
    macca31 New Member
    Yes. I replicated the way the old one was in.
  4. Dave does Gas
    is this the old Cdi with the grey facia or is it the Greenstar version
  5. macca31
    macca31 New Member
    I think it’s the old cdi as it does have a green facia
  6. I must be sad
    I must be sad New Member
    Your right! I hate doing them in the 24 it’s a right ****
    It likely be the flat plate blocked, I normally do both cos there so **** to get into
  7. I must be sad
    Try talking the filters out of the taps if it’s a **** flow they won’t fire
  8. Boilerdoktor
    Boilerdoktor New Member
    When you turn a hot tap on , do you get a red demand light ?
  9. macca31
    macca31 New Member
    Problem solved! I noticed,when looking at the diverter valve diaphragm pin from underneath that the black plastic disc was missing from it therefore it couldn’t operate the switch. After a quick look around I found it wedged between the floor boards under the boiler. Reattached it and now hot water!
    Thanks for all your help. Really appreciated.
