Worcester 24i timer connection
Discussion in 'Electricians' Talk' started by Barry mccardle, Nov 9, 2018.
  1. Barry mccardle
    Barry mccardle New Member
    Is this wired properly? Should the live and neutral not go to 1&2?
  2. Mike83
    Mike83 Well-Known Member
    L and N to 1 and 2 is correct.
  3. Barry mccardle
    Thanks for the quick reply.
    But white is in no2? White is not neutral, is it?
  4. Mike83
    Could be neutral. Colours don’t mean much to some people
  5. Mike83
    If it’s working or has been working then it’s correct
  6. Barry mccardle
    That’s the problem. My boiler went on the blink. Got a spark to try and change the board, he did not know what he was doing (so he could have messed with this) so I got a heating engineer to change the board and he did and said the timer was not working which was ok as I never used it but now I’m selling house and the new guy wants it fixed so I bought a new timer and it’s still the same. (Boiler works just the timer doesn’t)
    Hope that makes sense.
  7. Mike83
    Take a picture of the other end of the cable
  8. peter palmer
    peter palmer Well-Known Member
    This is the integral clock I take it, the one which clips to the front of the boiler? If so the internal wiring of the boiler could be any colour they chose to use.
  9. Barry mccardle
    Thanks guys. Problem solved.
    Spark took the front of the boiler off and the other end of the timer cable was not connected to anything.
    2min job.
