I moved 5 months ago into a retirement bungalow with one bathroom electric shower and 6 small radiators and a hot water tank in the bathroom . The old ideal boiler is 21 years old working fine but not quiet I have permission from my landlord to fit a new combi boiler and remove the old water tank I’ve read the Worcester Bosch green star 2000 is the quietest combi boiler at 43dB this would be ideal in my kitchen Unit in place of my boiler now which has a flu outside just below the guttering ! This boiler is around £700 at travis Perkins etc how much would the boiler and installation cost ?
It should take at least a full day. Might even be 2 full days. Plenty variables. If £1600-£2000 is for supply and installation then that’s a great price. Could be plenty work involved and you’ll usually need new controls and a magnetic filter. Also a new flue.
Is this a retirement complex, and is likely to be your home forever? Just a word of caution, if that does not sound too condescending: Does your rental agreement make the LL liable for repairs, maintenance and ongoing replacements? It is probably unlikely that they will pay for a new boiler just because the old one is a bit noisy, and your money is for you to decided how to spend. If they are responsible for repair and maintenance, do you run the risk of them refusing to pay for future repairs and maintenance as you changed the equipment to non standard? Maintenance and repairs can be expensive, if unlucky
Removing the water tank is simple. But you then need to make pipe alterations to eliminate the cylinder circuit from the new set up. This will be a couple hours. The system needs to be drained and old boiler removed. Another hour. New boiler installed and piped up. 2-6 hours depending on access. System filled and flushed then refilled. 2 hours with chemical flush Wiring 1 hour. Getting all materials and tools on and off site. 1 hour. Some jobs like this when seeing the finished article you wonder how it’s taken so long. But boiler changes do take time if done to a decent standard. The times above can all be variable. Some jobs are easy and some not so.
I have written permission to change to combi boiler and any alterations to go with it must be done by qualified plumber and up keep of new boiler will be my responsability service etc
I know there is expense of new boiler etc I have the money at 21 years old it’s not economical and heating a cylinder for just me is crazy imho as I’ve said I’ve read the Worcester Bosch is the quietest has Best Buy rating and they have sold millions of this model !
