Worktop joint position??? (with picture)
Discussion in 'Kitchen Fitters' Talk' started by CosRush, Oct 29, 2008.
  1. CosRush
    CosRush New Member
    Any advice with regards to the following worktop layout?
    I have a sink on the left and Integrated Oven and Hob to the front.
    Im unsure as to which position for the joints would be best and if the joints are best either side of the oven as in the first picture should I use metal strips instead of a mitre joint because of possible heat damage???
    Pic 1
    http://img.photobucket.com/albums/v385/CosRush/plan1.jpg
    Pic 2
    http://img.photobucket.com/albums/v385/CosRush/plan2.jpg
    Thanks in advance to all those who reply.
  2. Captain Leaky
    Captain Leaky New Member
    Personally I would go with the first option to keep the joint away from the sink. Either will work though.
  3. Rizzo
    Rizzo Member
    Another possible is to use straight 45 deg mitres, keeps away from hob and sink.
  4. bernieeccles
    bernieeccles Member
    I would not do it either way.
    Do the sink side joint as in pic one, so it is running away from the sink and do the hob piece right up to the right hand wall.
    Then the second joint away from that, so in essence, the second joint is at a right angle to the sink joint.
    Reasons being that it is much easier my way as it leaves the last (non aplliance piece) easier to fit.
    Don't use metal joining strips, it will look **** !
  5. bernieeccles
    bernieeccles Member
    Oooooo, a swear filter !
  6. Bernie's got it, easier to fit as well.
    Mitres every time, jointing strips are a health hazard, as well as looking carp
  7. russ295
    russ295 New Member
    ditto, females cut from the top face on both tops
  8. Danlowe
    Danlowe New Member
    do the join to left of the oven as in picture 1 - thus helping to keep water away from the join, and do the join to right of the oven as in picture 2
  9. CosRush
    CosRush New Member
    Thanks for all the replies.
    Only problem I have with the suggestion made by Bernie is that the outside edge (The worktop opposite the sink and next to the oven) is exposed and will have the edging strip on it.
    I figure this will be much easier if this piece is one length as in Pic 1. rather than 2 if I followed the suggestion of having the join to the right of the oven horizontally.
    Any major issues with pic.1 with reference to heat from the oven?
    I feel I have created more than enough support for that particular worktop.
  10. CosRush
    CosRush New Member
  11. bernieeccles
    bernieeccles Member
    Well in that case go with pic 1 as it will be easy to slide
    the "free" worktop up to the "oven" worktop and the edge the showend.
    Are you having a hob above the oven ? and will you have enough worktop material to fit the worktop connecting bolts.
    I take it, that your drawing is not to scale then.Heat should not be a problem with a decent oven.
  12. under the plinth
    under the plinth New Member
    If there isn't enough room to fit the bolts then you can coutersink some long screws to make the joint before the hob gets fitted but you'll have to be spot on getting the tops level.
  13. CosRush
    CosRush New Member
    Thanks again for the replies.
    I have approx. 10" of worktop each side of the Hob/oven.
  14. under the plinth
    That rules out my screws method then. Worktop bolts will do the trick. Easy to get too as well if you fit the hob after making the joint.
