Worktop up to range cooker
Discussion in 'Carpenters' Talk' started by John Bunyan, Feb 4, 2021.
  1. John Bunyan
    John Bunyan Member
    I'm replacing a 12mm or so composite/laminate worktop which butts up tight to the range both sides with a 38mm laminated chipboard. Should I leave a gap? And should I laminate the ends or use aluminium end strips? Thanks
  2. Tilt
    Tilt Screwfix Select
    Butt right up and laminate the ends........... No gaps, no strips............. unless the wife is in a good mood, Lol. :)
    John Bunyan likes this.
  3. John Bunyan
    John Bunyan Member
    Thanks for that, I did just as you said
    Tilt likes this.
