Wortop Support
Discussion in 'Carpenters' Talk' started by Carol1, May 31, 2019.
  1. Carol1
    Carol1 New Member
    Hi
    Just a bit of advice. I want to remove a 30cm cabinet from the end of a run of cabinets (next to the 30cm is a 50 cm and a 60cm cabinet and at the end a supported vacancy for washing machine of 60cm. These are all to the right of the 30cm cabinet nothing on the left just a vacancy where fridge freezer sits).
    Is is necessary to support the worktop (approx 35cm (with worktop overlap)). There will be no weight on the worktop length of 35cm just want to put a bin underneath and want to maximise space so rather not use a leg and don't want to drill wall for bracket if I can avoid it. Worktop is standard off shelf not marble or anything just board with laminate finish.
    Thank you
  2. gas monkey
    gas monkey Well-Known Member
  3. Carol1
    Carol1 New Member
    Thank you, so no support necessary, that is great (actually only 32.5cm):)
  4. Mr Rusty
    Mr Rusty Screwfix Select
    yes...................................................it'll be fine:p
