wot laser level?
Discussion in 'Carpenters' Talk' started by sammy toaster, Oct 17, 2008.
  1. sammy toaster
    sammy toaster New Member
    anyone know of a cheap laser level that can assist me to set out two houses in sidcup.?
  2. kaintheo
    kaintheo New Member
    well a rotating laser will be of the most benefit and I would always recommended leica or topcon.
    however, if your setting out 2 new houses from scratch then an optical (dumpy level) will be of more use as you don't wanna cock up your levels for planning do you.
  3. bonnie the botch
    bonnie the botch New Member
    hi sammy, you'll never get a level to work cheap in sidcup. just kiddin hire a dumpy as stated.
